Help choosing a case
9 Oct 2008
I need a case to fit the following:
(depth)
"mini" scythe ninja cooler
gtx280/gtx260
(height)
asus p5q deluxe
no water cooling
I was thinking the antec 300 although im sure if it would all fit
If it wont fit can you recommend one that will
thanks in advance
Nzxt tempest great case and pretty cheap as well
Im sure it is a good case but i heard people have problems plugging in there power plug on a 88xx card because the hdd rack is so close to the end of it.
If it can only just fit a 88xx then i dont see how i would be able to fit the bigger card like the gtx260/280 unless the hdd rack is removable (which i doubt)
doesnt your video card have the power connections on the side of the card rather than the end (which the older 8800 cards had). but yeah i recommend the antec 300
lol i don't actually have a gtx 260/280 yet so i don't know
but i have the rest of the parts i need and was just wondering if it would all fit
can anyone confirm that the gtx260/280 do have power sockets on the side rather than the back
thanks
dont know where you have heard that ive got a 4870 in mine and about 4 inches to spare to the hard drive rack, and also the hard drive racks are removable.
