Help choosing some ddr3
23 Feb 2009
Hi,
I was wondering if someone could advise me between these two sets of ram.
OCZ platinum 1600mhz ddr3 cl 7-7-7-24 or OCZ platinum 1866mhz cl 9-9-9-28.
I dont really know whether the faster frequency or the tighter timings would benefit me most. I use my pc mainly for gaming. I will also be looking to overclock my i7-920 (if that helps with decision).
Both sets of ram seem to be around the same price, with the 1866mhz ram maybe being around £5 cheaper.
Thanks in advance,
Phil.
Either are a touch excessive. With X58 and the triple channel memory, bandwidth isn't really an issue so memory speeds and latency don't mean very much.
1600mhz is sufficient for a bsck of 200 with the x8 multi, or 267 with the x6. Your board will not run at 267, so ram is certain not to be limiting if it is 1600mhz. So speed really isn't an issue. Out of the two I would go for the cl7 set, though given more options I think 1600mhz cl8 is the best choice.
Hi again,
I was also wondering why 1600 cl8 is the best choice over the 1600 cl7 that i listed?
Would you say corsair dominator 1600 cl8 is the best over the two sets i listed?
Phil.
