help cod4
Permabanned
28 Oct 2006
Bournemouth
gillied up, when im laying down in the field, and loads of men go past, with the tanks, where should i be hiding, i even tried going in between the two trees and we always end up getting spotted! And then i can't kill them all! Do i need to kill them all, or should i be doing something different?
on the far right hand side just inside the radiation area theres a jeep or something blown up, you can sit behind it in the radiation and not be killed or spotted
You can't kill them all.
Best thing to do is to crawl up the backside of the Scottish guy and sit just slightly angled to the left of him. If you crawl directly behind him then the soldiers (who cross at an angle) will end up walking on your legs. And obviously spotting you.
Great bit of game structure, very intense.
Keep behind your cpt (cant remember name right now), as close as you can - the AI won't run over him, that's my logic anyway
edit: too slow
I tried to play it as realistic as possible... so didn't go up the guys ass.... moved far right of him - and did as he said! Stay low, keep moving, don't engage.
Awesome game.
I just crawled forwards slowly around them all to the left. Just try and keep out of they're paths.
yep thats all you have to do. for a laugh i legged it back and took cover behind a fence or tree thing and tried to take them on. pop pop pop with sniper rifle. brilliant level. reminds me to play it again some time.
Easiest way i found was to sit infront of the front-most tree. I figured soldiers couldn't walk through trees so it was a safe bet, and sure enough, everything rumbled past. Really really intense part of the game, excellent design.
