- 17 Jun 2010
So I've just finished moving my pc into the new case I got along side some new upgrades.
I go to put the front back on and the Corsair h100 doesn't fit ...
So I'm basically stuck with no dust filter/front cover on the front of the pc.
I bought the Fractal Design Torrent Compact, I am needing a cooler for the 5800x that will clear my RAM, which is Corsair Dominator Platinum RGB.
I'm a bit out of the loop so not sure what's out there and what's good and what will fit.
Can anyone help at all please?
