I have a i9 7900x and I set the cpu ratio to 4.6GHz with a 1.15v the AVX is at 4.4Ghz and AVX-512 is at 4.3GHz. While am NOT stress testing the cpu in ROG CPU-Z it shows the core speed at 4600Mhz (4.6GHz) and the "Multiplier" also x46.0 which is fine. But as soon as I start stress testing the core speed goes to 4.4GHz and does not get any where near 4.6GHz sometime goes to 4.5GHz for a few seconds then drops back down to 4.4GHz even the Multiplier is showing x44.0? Know this is the speed of the "AVX" in bios 4400MHz (4.4GHz) so why would it be doing this? is there another setting I need to change? Also max temp am getting is 72c
