HELP : Data recovery
27 Jul 2005
The Orion Spur
Hello, I have a client that gave me a HDD yesterday that has failed and he is desperate to recover the information on the drive, I have various data recovery software but the problem is the drive isn't even being recognised in the bios, it's an old ATA-100 30gig Maxtor drive.
Symptoms,
Drive spins up ok but I don't feel the arm/head judder like you do when most drives power up.
No HDD activity light while attempting to boot.
Not being Recognised in the BIOS
Two systems I tested it in failed to even boot into windows while the drive was plugged in.
I've made sure jumpers/cables are fine etc.
I've told him that there really isn't much chance of getting the data off unless it's sent away to a proper data recovery centre where they will most probably open the drive up in a controlled environment but that would be expensive and he doesn't really want to spend out a lot.
Anyone have any ideas?
Do you think that I'm am correct based on the information I have provided?
Thank you.
Could try one of those SATA/IDE > USB docks - can then plug it in after Windows loads (and pray!)
I had a failing hard drive before that just would not work, tried the freezer trick, nothing worked.
In frustration, I kicked it really hard along the floor into a desk. Upon plugging it in, it worked again!
Couldn't believe it, still used as a temp files drive in a spare pc :D
I had a Seagate 120 GB disk fail in 2009, it was spinning slowly but wouldn't boot. Despite this I managed to use my Acronis bootable CD and imaged the failed disk across to a new 500 GB disk in an e-sata external dock. The process took an hour or so but it worked for me.
There's also the free clonezilla bootable which can image too.
