Help deciding on a replacement card
If it was me i'd wait until the other card comes back, sell it and buy a 290/780.
I don't think a 280x will be that much of an upgrade as they are pretty much rebadged 7970's, iirc the 7950 wasn't that far behind a 7970 performance wise.
I would get a rough idea of how much your fixed GPU will sell for and add that to your budget.
So if you can get £100 for it, go for a £300 GPU such as an R9 290 custom cooled version.
