Hi all - first post here so please bear with me.
I'm planning to build a PC for my mum who's in her late 60s but really quite computer literate. She does the usual email/internet etc. but also spends a fair bit of time creating videos with Photostory. Now I don't think this is the same sort of processing requirement as full encoding but I'm guessing there will be a bit of processor load: having looked at the software briefly it has an option for CUDA, for example. She also does a bit of photo editing, not full photoshop but retouching and the like.
Her current PC is aeons old, has been upgraded a few times by yours truly and is still grinding. I can't even remember what the spec is, but it's out of date, especially when using Photostory. She uses a fair bit of HDD storage and she recently bought a 1TB external drive, which I'm going to suggest she uses as a backup device for her new rig (it has a one-touch backup button).
It's been years since I've built or spent more than an hour messing around with PCs (although I did recently set up a new Ubuntu box at home). I'm waaaaay out of touch with current processors, mobos, architecture etc., but I've done a fair bit of searching and ploughed through the forum, faqs and the like. Her primary need, IMO, is for it to be as future proof as possible, i.e. limited necessary upgrades for the next 3-5 years but an ability to crank it up a decent amount after that or if her demands change. I live 350 miles away and won't be around to bolt new bits on as easily as might otherwise be the case. I will be setting the thing up at my home, testing it for a week and basically getting it ready for use - then carting it down on my next visit.
Current idea for spec…
Internals:
Intel i5-2500K 3.30GHz (Sandybridge) Retail £184.99
Gigabyte Z68AP-D3 Intel Z68 DDR3 Motherboard £84.98
Kingston HGG 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel £41.99
Arctic Cooling Freezer 13 High Performance CPU Cooler £17.99
Storage:
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) £81.98
Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache £109.99
Case & PSU:
Cooler Master Elite 342 Case - Black £24.98
OcUK Swift 650W V2 Silent Power Supply £26.99
Total coming in at £588 inc vat and shipping. Am I right in thinking that I should be able to OC it up to about 4.5GHz stable? If so, that will give her a relative beast of a machine that boots in sub 20s (quite important) and is lightning fast for everything she needs (i.e. anything except gaming).
Yes, it's probably over the top, but the other option is to go for a lower-power rig which she might outgrow within 4-5 years and probably need an upgrade within 2-3, which isn’t as ideal, especially if I’m only saving her about £100.
A few questions: is the case, cooling & PSU combo sufficient for a decent overclock of, say 4.5GHz? I've seen the mobo suggested as a decent budget OC board and the 2500K is a beauty, so that just leaves the bits around them. I really fancy getting her a SSD as she'll love the quick boot times and it'll actually encourage her to use the computer more! 8GB is way more than what she has now and it'll be easy to add another 8GB if she gets into proper video editing etc. She already has an external USB DVD writer, monitor (although I'll need to check it has HDMI input) and the other usuals, so the only extra add on will be Windows 7 which is about £80 for an OEM version, I think.
If any of the components aren’t good enough then I might need to free up a bit of budget, so that could be where I slip down to an i3 (so no OC). That’d be a shame, though and I’d probably be inclined to stick with the i5k even if it costs here a few more £. I don't see the point of adding a GPU; I'm presuming the onboard graphics will be plenty good enough for windows and without hardcore video encoding CUDA wouldn't be worth it?
Alternatively, we could ditch the internal 1TB drive and use the external drive for storage (as she does now) but then that means no backup, which is a very bad idea IMO…
Any thoughts, comments, observations etc.? Have I forgotten something obvious (cables?) as it seems a pretty reasonable price?!?!
Thanks in advance
Paul
Internals:
Storage:
Case & PSU:
Thanks in advance
Paul
this system is way way way more than she probably needs but I would bet good money it will last her for over 5 years.
Buy a decent screen with some of the saved money from reducing the massive-overkill spec.
