Help E6300 underclocked!!
Permabanned
9 Aug 2006
Hi all,
i recently got a new pc ( sig ) and notices that mt cou is only running at 1.4ghz i thought this maybe down to my ram not being able to run at its full speed because my gigabyte mobo is just a cheap crap one im using until the good ones are released, i dont want to raise the fsb to the normal voltage as the intel ICH7 is running at 55oC with a heatsink, i have cpu z and it says my multi is at 7, the bus speed is at 199.5, and the FSB is at 798 and voltage is at 1.15, anyone have any suggestions as to what is causing the problem
The new Intel range slow down when you're not running anything like a game or video file, it keeps the temperature down and prolongs the life of the chip. Don't worry, I was worried at first.
thanks m8, so it will speed up when im playing a game or sumthing
That's the size of it, Intel's Enhanced Speedstep......can be turned off if you like, but nice for everyday use :)
Your board probably doesn't recognise the chip properly (you may have a B2 revision or similar). In which case update the BIOS, otherwise set your FSB to 266.
AceCobra said:
My gigabyte ds3 read by e6300 as a 466! (7*66)
Updated the bios and all sorted.
Martin.
So did mine when i had the F1 bios but the clock speed was correct even though it said 66*7 lol :cool:
