Help - E6750 running at 2.13
12 Apr 2008
Just installed new mobo, Gigabyte 945gcm-s2l. I cant get cpu to run at 2.66 posting on boot as running 2.13.
RAM is corsair ddr2 677mhz
Any help much appreciated
Increase the FSB to 333mhz and check the memory speed, as the multiplier / divider for the memory may need to be changed, hopefully save and exit.
Frequency voltage menu showing OC fsb1333 core.2 cpu [Auto]
Cpu Host clock control enabled
CPU host frewuency 333
Pci freq auto
mem freq 833
cpu frew 2.66 (333x8)
Dimm overvoltage [norm]
fsb overvoltage [norm]
cpu overvoltage [norm]
normal cpu vcore 1.325
Help lol
Pci freq auto
mem freq 833
Help lol
i save and exit and it reverts back to
fsb1333 core.2 cpu [disabled]
Cpu Host clock control disabled
Pci freq auto
mem freq 667
cpu frew 2.13 (266x8)
Looks like you need to change the memory multiplier to allow your memory to run at 667mhz.
Also check page 48 in the manual regards 1333mhz cpu's.
O.C FSB1333 Core 2 CPU
Enable use of a CoreTM 2 CPU with 1333 MHz FSB through overclocking. You must install the
FSB 1333 MHz CoreTM 2 CPU with DDR2 533 (or above) memory module(s).
Auto Set this item to Auto. Then save the changes and restart your computer.
During the POST, a message will appear asking if you want to enable the use
of a FSB 1333 CoreTM 2 processor. Press <Y> to confirm or <N> to reject. Or
press any key to continue the POST. (Default value)
Disabled Disable this function.
Enabled Enable this function
EDIT: Enable FSB 1333 core.2 cpu.
