Sorry, it's chassis fans. Is this okay, I'm quite worried.Depends on what the fan is and what it is doing! I wouldn't worry too much about a family running around 5% over speed.
Are you talking about a CPU fan? How is it you know it is running that fast?
They are plugged into the Motherboard header and I can see the speed of the fans on the bios. The fans are corsair rgb.How is it you can see it is running overspeed?
Are the fans good quality or are they cheap Ebay crap?
Are the fans plugged into the motherboard headers?
Just had a look at your other threads fella and have decided to pop you on my ignore list.My fan speed is 1400 ±10% RPM. Its running below 1500 so it's normal. Must just be a faulty fan.
What have I done wrong?Just had a look at your other threads fella and have decided to pop you on my ignore list.
