I recently got a USB Razer Kraken 7.1 headset, which is now the SECOND one I have used as I got it replaced for what I thought and their support had said was faulty, as I'm always getting a humming sound, that increases in volume along with whatever is playing out the headset.
Also the sound quality (of what I can hear) is bad.
I have used a USB headset in the past, and had to send it back also for the same problem but now Im sure it wasnt the headset but my PC.
Could it be a grounding problem?
Im noob when it comes to this stuff so I thought I would get help from the pro's.
Here is a pic of the inside of my pc, bit messy but any advice on what may help stop this issue Im getting?
http://i61.tinypic.com/13z5mie.jpg
Thank you.
Its either fixing the problem, or getting this http://www.overclockers.co.uk/showproduct.php?prodid=SC-001-AS which is on offer, and sticking to my current steel series jack headset.
Thank you.
