Help for a 27" ^ ^
24 Sep 2011
Hello everybody i've to buy a 27" monitor but i'm not able to chose between the followings:
1 Apple Display (think it's the best quality)
2 Dell 27" (got a 24" E248WFP atm so it's heavy AG cover is not a trouble, at least i think)
3 Hazro 27" WC
4 Fourth option?
I'll buy the monitor from Italy so one of my main target is to buy a SOLID product, can someone hepl me chosing one?
Tks so much and sorry if my really bad english
Best Regards, Loris
P.S. Price is not a problem if will bring high quality and less post buy problems
Hi there,
I would go for the dell.
The quality is just as good as the Apple (it uses the same panel) and Dell's warranty is also excellent. Plus it has more connectivity options and the AG coating means you aren't staring at a mirror when you are in a bright room.
The Hazro is a nice monitor if you want a big, high quality monitor on a bugdet - but there have been some quality control issues (like trapped dust in between the glass cover and the panel) and the Hazro dead pixel policy is not great. If you can afford the Dell, then I would go for it, as the warranty and build quality are hard to beat.
Tks so much for your reply..in fact i think my best chose will be between Dell and Apple because i can find them in Italy too..tks so much for your help.
Best Regards, Loris!
