Help - for my mate =]
22 Jan 2010
Well my mate has a problem which occurs sometimes here is a quote from him
"Whatever i seem to be doing on my pc e.g. on Internet, playing games sometimes my pc freezes for about a minute or 2, when it freezes you can move the mouse and see the pointer moving but cant do anything, I press Ctrl, Alt, Del then after about 30 seconds or a minute it goes to the page where you can select task manager click cancel and its ok then (On vista btw), just frustrating because the pc is only 2 months old done virus scans and found nothing."
His PC specs are:
AMD Athlon II X2 250 Processor 3013 Mhz
500GB Hard drive
4 Gig ram
Geforce Gts 250 graphics card
Gigabyte GA-M61PME
task manager pop up 30 secs after ctrl, alt, del.
check for which process is eating CPU.
need post this in general hardware or software
