20 Mar 2016 at 21:42 #1 jammir jammir Associate Joined 11 Feb 2007 Posts 1,716 Location London / Essex Need help formatted a raid 5 array by mistake is there a way to get the data back?? and its a 11TB array
20 Mar 2016 at 22:03 #2 Armageus Armageus Don Joined 19 May 2012 Posts 20,301 Location Spalding, Lincolnshire Depends how much you value your data - if you can cope with possible data loss, then something like: http://www.easeus.com/datarecoverywizardpro/ will likely do the job. However, if you need to minimize the risk (e.g. irreplaceable photos), then I would get in touch with a data recovery specialist. Too late now, but RAID is not a replacement for Backups
21 Mar 2016 at 00:50 #3 bledd bledd Don Joined 21 Oct 2002 Posts 46,883 Location Parts Unknown Restore from your backup.
21 Mar 2016 at 12:32 #4 jammir jammir Associate OP Joined 11 Feb 2007 Posts 1,716 Location London / Essex This was the one array that was not backed up fully I do have a backup of about 30-35% of this drive. Running a recovery tool which is saying deep scan will take 14 hours
21 Mar 2016 at 15:09 #5 bledd bledd Don Joined 21 Oct 2002 Posts 46,883 Location Parts Unknown This is probably your best bet. (without sending them off) https://www.runtime.org/raid.htm
21 Mar 2016 at 16:22 #6 KIA KIA Man of Honour Joined 14 Nov 2004 Posts 13,895 Quick format? Full format? Windows? Linux? Motherboard RAID? Much more information is required.
21 Mar 2016 at 16:57 #7 jammir jammir Associate OP Joined 11 Feb 2007 Posts 1,716 Location London / Essex Quick format under Windows disk management raid 5 with hardware raid card adaptec 51645
22 Mar 2016 at 17:47 #8 KIA KIA Man of Honour Joined 14 Nov 2004 Posts 13,895 In that case, GetDataBack for NTFS may be worth trying, since you haven't deleted the array.
