Hi,
I have a hotpoint fffl 2000 fridge freezer.
Yesterday we noticed food was not getting cold in the fridge compartment.
There's not much ice in the freezer compartment so I don't think its a heater issue.
The circulating fan works as its still blowing in the freezer but the air is not
getting to the top fridge through the ducting.
Took most of the internal covers off. Thawed any ice that was present away to make sure there was no blockages in the ducts and they are all ok too.
Reassembled and same result.
No alarms are sounding even though the fridge compartment is too warm.
Any idea what controls the amount of air that gets directed into the fridge compartment on this model?
Temperature sensor issue? cant tell where this is in the fridge.
The air tech columb in the back of the fridge was removed to check for blockages. There is a wire with a molex connector going into this but don't know what it controls and most of it is sealed.
I'd appreciate any suggestions.
thanks.
below is an image of the fridge compartment
thanks.
