HELP - I scewed up...
17 May 2003
Milton Keynes
This is SO embarrassing - especially for how long I have been doing stuff like this. :(
I upgraded the bios on my system last night. Why? Dunno, just felt like it as I was doing lots of other stuff.
However I forgot to stop the cmos being refreshed.
Yep, I have lost my sodding profiles.
Does anyone have the 4ghz overclock profile for this;
*OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz Max / Gigabyte EX58-UD5 Intel X58 Motherboard / Corsair 6GB DDR3 PC3-12800C9 1600MHz DDR3 Bundle
4.00GHz Overclock
I have phoned OC, but they don't have one for this board anymore and they suggested I post in here.
Thanks
Mike
I'm 90% sure I have it, because I did the same thing ages ago and lost my profile, so I got OC to email me a new one.
However, I couldn't ever get it to work (not sure if it's because I have a dodgy cpu or if the bios update broke it). I'll have a look for you when I get home.
4.00GHz Overclock
Thanks
Mike
Check my post I made this morning. Most of the settings should be here. If they are not give me a shout and I'll find out what is missing.
Mine has the Patriot memory but it will be similar I think.
Under Advanced CPU settings:
C3/C6/C7 State support Disabled
Everything else is enabled.
I'm just on my way out to work now, so I'll check back later if you are still stuck.
Tried your figures, thanks [and messed around with voltage on cpu and memory, but it would not boot into windows.
Hi, l'm using Patriot memory -
OC BIOS x58a UD5 4.0GHz > these are my settings so use them as a guide, as always you overclock at your own risk m8.
Advanced CPU Features:
CPU Clock Ratio ..............................[20x]
Intel(R) Turbo Boost Tech ....................Enabled]
CPU Cores Enabled ............................[All]
CPU Multi Threading ..........................[Enabled]
CPU Enhanced Halt (C1E) ......................[Enabled]
C3/C6/C7 State Support .......................[Disabled]
CPU Thermal Monitor ..........................[Enabled]
CPU EIST Function ............................[Enabled]
Virtualization Technology ....................[Enabled]
Bi-Directional PROCHOT .......................[Enabled]
Uncore & QPI Features:
QPI Link Speed ...............................[x36]
Uncore Frequency .............................[x16]
Isonchronous Frequency .......................[Enabled]
Standard Clock Control:
Base Clock (BCLK) Control ....................[Enabled]
BCLK Frequency (MHz) .........................[192]
PCI Express Frequency (MHz) ..................[101]
C.I.A.2.......................................[Disabled]
Advanced Clock Control:
CPU Clock Drive ..............................[800mV]
PCI Express Clock Drive ......................[900mV]
CPU Clock Skew ...............................[0ps]
IOH Clock Skew ...............................[0ps]
Advanced DRAM Features:
Performance Enhance ..........................[turbo]
Extreme Memory Profile (X.M.P) ...............[Disabled]
System Memory Multiplier (SPD) ...............[8x ] = 1536Mhz
DRAM Timing Selectable (SPD) .................[EXPERT]
Channel A > B > C
Channel A Timing Settings:
##Channel A Standard Timing Control##
CAS Latency Time .............................[8]
tRCD .........................................[8]
tRP ..........................................[8]
tRAS .........................................[24]
CR............................................[2]
##Channel A Advanced Timing Control##
tRC ..........................................[Auto]
tRRD .........................................[Auto]
tWTR .........................................[Auto]
tWR ..........................................[Auto]
tWTP .........................................[Auto]
tWL ..........................................[Auto]
tRFC .........................................[Auto]
tRTP .........................................[Auto]
tFAW .........................................[Auto]
Command Rate (CMD) ......[1]
##Channel A Misc Timing Control##
Round Trip Latency ...........................[Auto]
Advanced Voltage Control:
CPU
Load Line Calibration ........................[Enabled]
CPU Vcore ....................................[1.26250v]
Dynamic Vcore(DVID)...........................[0.0000]
QPI/VTT Voltage 1.150v .......................[1.295v]
CPU PLL 1.800v ...............................[1.800v]
MCH/ICH
PCIE 1.500v ..................................[1.500v]
QPI PLL 1.100v ...............................[1.140v]
IOH Core 1.100v ..............................[1.120v]
ICH I/O 1.500v ...............................[1.500v]
ICH Core 1.1v ................................[1.140v]
DRAM
DRAM Voltage 1.500v ..........................[1.6v]
DRAM Termination 0.750v.......................[0.750V]
Ch-B Data VRef. 0.750v........................[0.750V]
Ch-C Data VRef. 0.750v........................[0.750V]
Ch-A Address VRef. 0.750v.....................[0.750V]
Ch-B Address VRef. 0.750v.....................[0.750V]
Ch-C Address VRef. 0.750v.....................[0.750V]
Hope this helps, if it does not boot into desktop increase the CPU Voltage a step at a time.
oldphart. :)
Hi, you do get a slight performance increase at 101mhz l believe, but somebody can correct me if l'm wrong. You can set it at 100mhz, its been at 101mhz for just over 2 years no problens at all.
@OLDPHART.
Many thanks from an old git. Booted first time into W7.
I havn't stressed it yet, but the boot was soo promising.
Thanks all.
Mike
BUGGER!
Well it lasted 4 hours - I was just going to look at F1 on beeb sports page and the pc just quit.
Restarted itself, got the W7 logo screen up and thats as far as it has gone since.
I can get into "safe" mode without networking and not with networking.
I cant really do anything in safe mode. Not even install the drivers for the new GFX card [as msi software starts to check system pc quits]
This last was on my backup disc that I put in in case the others W7 had been corrupted.
SO FAR I HAVE;
Swapped the memory around in case of memory damage on one of the pieces.
Swapped HDs out.
Gone back to "safe" defaults on BIOS as well as "turbo" defaults [2.86].
Every time it quits when loading W7.
So CPU or board gone?
DOn't have a spare board to try chip nor spare chip to try board.
BUGGER AND DAMMIT!
Try clearing the c-moss > power down take 24 pin atx cable out + 6 pin atx , press power button to discharge last of power in capacitors, press c-moss button on the back of PC hold in for about 30sec's.
Have you set your memory volts to max? Also increase your core volts a notch, test with intelburntest set your threads to 8 and test at standard 10 runs. If it fails up your core volts again and test, if its stable after 10 runs, try 5 runs on high, IBT is all you need to test for stability it has never let me down.
http://www.overclockers.co.uk/showproduct.php?prodid=MY-205-CS&groupid=701&catid=8&subcat=1389
timings 9.9.9.24 > 1.65v
Always install OS, etc at default speed.
Currently running memtest 68+, also got ultimate boot cd and will be doing prime.
**I noticed on your settings that you have the CR on the Memory set to 2, but set to 1 on the advanced memory. **** if I do that the mem gets set to the advanced's 1....
Yep, done the cmos [and removed the battery... :>}]
I shall get the intelburntest in a mo.
**I assume it can run in DOS?** [as I don't have windows.....]
**** downloaded. - It needs win. will ty it in safe mode and see if it will work......*****
Just concerned that it ran for 4 hours fine and now ..... NOWT!
Do you know what the "safe" level to put vcore up to?
Thanks, BTW, for your help on this.
Prime on the so-called UBD does not work [nor does a few others either]
Memory OK.
So it seems either the cpu or the MB are fragged.
Hiya,
Did you find your version btw?
OFC as its probably the cpu thats stuffed, I won't need it yet..... :(
I was adviced by the OCUK tech's not to go over 1.35 core volts, to keep temps down and for CPU life, no boot into desktop and run IBT.
How did you update your BIOS? Over the net using @BIOS or manually using Q-Flash, never update Bios over the net, to much to go wrong.
The only thing that went wrong on the bios was me....
I just forgot to NOT clear the CMOS.
Can't get desktop. Starts to load windows, clicks and starts to reboot.
> I just forgot to NOT clear the CMOS. <
Hi, l'm a bit confused about > I just forgot to NOT clear the CMOS. < did you use Q-Flash to update bios? Did you save the origonal Bios if so use Q-Flash and follow the instructions on page 72 in your manual follow them to the letter. You can't go wrong or try another Bios F6, l tend to keep away from BETA BIOS UPDATES, down load your manual if you can't find it.
