Help identifying ancient hard drive interface.
Caporegime
12 Mar 2004
England
I have this old laptop with the screen broken and os screwed up and I want to recover some photos from it, but the hard drive has a connector I've never seen before, every laptop I've ever had has been standard sata.
i'm sure i've seen a thread like this before on this forum, the interface seems familiar but i can't find the thread.
EDIT: i counted how many pins is had and googled seems to be laptop ide
44 pin ide as used in laptops. You'll need a converter to hook it up to a desktop pc. You've not opened many laptops then? This was common up to 2005-2006 easily.
I've opened numerous laptops, they just never used this connection, my nov 06 laptop used sata even.
Its just IDE (you know, the interface that dominated for years and years before SATA?), nothing special. Check google or Ebay for a 44 pin laptop ide to desktop ide convertor. I've even got a few Core 2 laptops using IDE only, so its not exactly ancient ;)
You know now I think about it, I'm sure I came across one of these before in some Roman ruins. ;)
Found an adaptor on Amazon, thanks guys. :)
No its Parallel ATA sometimes called PATA which was the interface replaced by SATA, IDE stands for Integrated Drive Electronics and is a type of drive design to which PATA and SATA both belong but SCSI does not
Well, whatever, but when we used IDE drives, being as there was no such thing as SATA there was no need to distinguish the drives of the day as PATA. They were just known as IDE drives, or ata. Everyone just called the cables 'IDE cables.'
The laptop drives had 44 pins as opposed to the desktop having 40 pins as the power to the drive was supplied through the extra pins.
Thanks for the lesson, did you get that from a online dictonary? As the above poster said, back in the days before SATA there was PATA and SCSI but no one thought of IDE as PATA or called it that, we always called and will always call it IDE, i've never heard it being referred to as parallel ATA by anyone whos been in the business a while. Same goes for hoover, scotch tape, band aid etc..
