Help installing SSD?
27 May 2009
I have purchased an OCZ 120GB vertex 3 SSD.
My MB is an asus maximus IV.
Do I just plug the SSD into one of the sata3 ports, enable AHCI and install W7 to the SSD?
What other settings and precautions should I take?
Once W7 is installed, what settings should I use or turn off such as pagefile etc.
I am using a WD 1TB caviar black also for my games.
Thanks.
Most firmware updates will not wipe your data but it's best to upgrade before you put any data on it or make a backup beforehand just in case.
Thanks for all of the help.
So very much appreciated.
Really looking forward to having my OS on a SSD now.
I have heard games such as arma 2 and world of warcraft are fantastic on a SSD.
I own a. asus maximusIV, should I plug the SSD into the sata6GB intel or marvell controller?
i did have a read of that before posting but it was a bit over my head.
is it basically just a performance/compatibility enhancement feature worth installing on SSDs ?
It's a standard that allows developers to use SATA drives in the most efficient manner which is why you get the best performance in this mode.
