Help, it’s not wotking
The odds of one person having this many failed ram sticks is so low we might as rule that out imo.
You say you've removed the cpu and refitted it but did you check the motherboard socket for bent pins? All it takes is one pin to be bent and it could mess up everything.
As above, is it the most up to date bios etc...
If it passes memtest it isn't a dead set of ram.
Can you confirm if you have updated the bios and reset bios to default settings?
Latest bios, has been reset to default, no xmp applied.
playing rust yesterday and the game crashed out,
I did find a post where someone advised upping the memory controller voltage slightly, so have done this.
I have 4 bsod that “point” in someway to memory issue. I have a 1tb 980 pro as boot drive, it is updated to latest firmware, I know the 2tb has issues that need the update.
have been through the entire system all drivers are up to date, all power correctly connected.
btw thanks for the replies, kinda helping my sanity with this.
so
latest.
decided to send motherboard back to get checked over, rebuilt an older i7 7700k system, on windows 10
used the same case, gpu and psu.
installed all drivers,
checked device manager, all ok
twice today bsod
system_thread_exception_not_handled nvlddmkm.sys
system_service_exception ntoskrnl.exe
so im looking more towards gpu, its an asus 3080
any opinions welcome
i'm leaning towards gpu with that first error. reinstall an older nvidia driver. if you don't use geforce experience i can give you a bloat/telemetry free version that i use.
