Help! I've Locked Myself In My Bedroom And Can't Get Out
Tap the morse code for SOS on the wall?
Erm if you don't mind destroying the door you could break it down.. or perhaps if you have a knife or something you could prise the lock of?
M
Why don't you post your address on here, maybe someone in the area could come to your aid?
___________________
Do *NOT* listen to the above advice ;)
G-MAN2004 said:
Did you use a paper clip? ;)
Actually I used a key, which uh... is more impressive than it sounds considering it was one of those bathroom locks that doesn't use a key. The bolt on the outside that attaches to the thing you turn on the inside fell out after I'd locked it. Luckily one of my keys was just the right size to fit diagonally in the square shaped hole in the lock mechanism. Now I think about it, it really shouldn't have taken 30 minutes for me to think of trying that :D
Blakey0500 said:
umm can you explain more??
There should be pins on the hinges of the door, these can be removed and the door can be moved... if they haven't been painted over about 10 times like mine that is.
P.S LOL @ YOU! :D
P.S LOL @ YOU! :D
ahh i get you now, yes i have these, just wish i had my pliers with me to pull them out.. hmmm
You'll never last till the morning. You have 3 options..
1) Call the fire brigade and see what they say.
2) Flash a passer by so they report you to the police / signal to them that you're stuck.. depends how quick you want somebody to come.
3) Unscrew the lock and try your luck.
Run head first into the door, create a hole and jump through.
Atleast it solves the toilet problem.. sort of.
No it won't. It will more likely mean that he has a dent in the door, a bump on his head, and having wet himself after having fallen unconcious. Actully.. its a good idea. Do it! :D
Exactly, atleast he wont feel bad wetting himself.
And if it does work, he ends up with the story of how he got out :D.
4) Urinate in a bottle or a glass or indeed any container you can find ;) Plastic bag? :D Just don't get a hole in it! :eek:
You must have a camera there with you. Produce a panoramic shot of the room and then we'll see what we can MacGyver for you. Although I'm all for the window + curtain parachutes myself.
