Help! (maths)
28 Oct 2006
Sufferlandria
I need to find the inverse of a function.
Its been a good year or two since i did my higher maths and im not sure i remember it correctly.
f(x) = 4x + 3
so the inverse is 1/4x -3 ?
f(x) = 4x + 3
if the inverse of f(x) is f'(x) then f(f'(x)) = x.
So, to check your example:
4(1/4x-3) + 3 = 1/x -12 + 3 = 1/x -9.
So your answer is wrong.
EDIT: I've assumed that by 1/4x you mean 1 divided by 4x, as opposed to x divided by 4. Either way the answer is incorrect, though...
Using the "interchanging variables" method: (swap variables around and solve for y)
y = 4x + 3
Changing variables:
x = 4y + 3
(x - 3) / 4 = y
Therefore f^-1(x) = (x - 3) / 4
Test: if x = 2, f(x) = 11
f^-1(11) = 2 :)
Don't want to start a new thread.
But basically, what is that symbol {x E R}? The topic is functions, anyone know?
I believe it means x is all real numbers.
