Help me build a computer please.
7 Jan 2013
Hi there,
Haven't used this before, recommended by a friend, so apologies if I do anything wrong.
Also very new to building computers, I know what things like the CPU, ram and GPU do and generally that bigger numbers mean better things, but I don't know what I'm doing when it comes to choosing a set up.
Basically, I need everything I require to build a computer for less than £600. I would like to get in to PC gaming, so would like one which can play most new games on around medium settings. Looking to get crysis 3 when that comes out so that could be a guide.
Not bothered about dual monitors at the moment, I'm fine with one, if that changes anything.
Anything I have missed out please ask.
Sorry this might be a bit demanding, but I really am clueless on this kind of thing and incredibly indecisive so I need a bit of help.
Thanks in advance,
Ollie.
No graphics and an i5?
I edited the post it wasn't meant for this thread fella. It's late, I made a mistake but corrected it almost before you could post ;) Having to pay for an OS chips into the budget quite a bit.
Any GPU lower than the 2GB 7850 is false economy in my eyes. He could consider a trinity setup but intels 1155 socket would be the better platform to build on
I'd go with something similar.
Oh hell, why not... :)
YOUR BASKET
1 x Gigabyte ATI Radeon HD 7850 OC Windforce 2X 2048MB GDDR5 PCI-Express Graphics Card £155.99
1 x Intel Core i3-3220 3.30GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £89.99
1 x Microsoft Windows 8 64-Bit DVD - OEM (WN7-00403) £79.99
1 x Asus P8Z77-V LX2 Intel Z77 (Socket 1155) DDR3 Motherboard £79.99
1 x Corsair Builder Series CX 500w Modular '80 Plus Bronze' Power Supply (CP-9020059-UK) £49.99
1 x BitFenix Shinobi USB3.0 Gaming Case - Black £46.98
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) £44.99
1 x TeamGroup Elite 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £35.99
1 x Samsung SH-224BB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM £17.99
Total : £616.00 (includes shipping : £11.75).
Bit more in budget, but it's a 500GB HDD. I'm still no fan of windows 8, prefers windows 7, but either you feel will work for you.
Good build by Hono (hello btw!) above, if you can stretch £30 its a great build for the price. :)
Hey bud, good to see you back :)
Yes sadly it is over budget. There are cheaper cases which would help trim off a few quid, the teamgroup RAM is a little cheaper too but I dont really trust it and it's a higher CAS rating (worse technically). I'm sure others will take a red hot crack at it
The spec has a 7850 GPU
Yes it does. I don't understand the point of his post, I corrected the mistake I made by posting the wrong basket.
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x MSI Z77A-G43 Intel Z77 (Socket 1155) DDR3 Motherboard - FREE Alpenföhn Civetta Cooler!! £72.98
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) £59.99
1 x XFX Pro 450W Core Edition '80 Plus Bronze' Power Supply £43.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) £39.95
Total : £632.86 (includes shipping : £12.50).
Still over budget but roughly the same price as my last spec. However if you use the developers copy of windows 8 for free as a try before you buy, you can get the i5K and mildly overclock it on this mobo with it's included heatsink. After 3 months you can buy an OS and choose between windows 8 or get 7 if you don't like 8.
All food for thought, I look forward to hearing what you think
YOUR BASKET
Looks like the kind of thing I'm looking at. I guess it's over budget if bought from overclockers, but I might be able to save a few quid elsewhere to bring it down to budget. Also, is it necessary to spend £50 on that case? Only has one average review, and there are ones which appear to provide more ventilation for £20 less. Any particular reason to buy that one?
Thanks.
Nothing wrong with the Shinobi. Nice case, can be pimped with extras if and when you feel the need. Case is personal preference at the end of the day.
Have a look at the Zalman Z9 U3 (it's not stocked here), that's my fav starters case. Digital temp display, fan controller, 3 fans (2 led blue), proper side window and USB3 ports, upgraded over the Z9 plus. Has a P4/8 extension to route the cable behind the mobo tray. Only real downside is you have to route cables out the back for the front USB3 ports unless you buy an adapter for the mobo header (eg silverstone cp09 adapter)
The xigmatek looks great, I'm not not too bothered about how it looks.
Won't be ordering until the start of February so they may get stock in before then.
Also, what is the advantage of USB 3.0? Is it really important?
Thanks for the help guys, pretty clear on my specs now.
YOUR BASKET
+1
