Because of the difficulties in finding stock ive ended up ordering extra fittins and for some reason I have 7m of tubing
Total spend on water bits so far is £700 :O
I best make a good job of the build.
7m ?! Then again seeing as it's my first time and sourcing stuff is bad here, I think I ll order quite a few tubes too, for practising and in future if I decide to change up the loop.
By the way does it matter which acrylic tube I buy, manufacturer wise? The bitspower fittings I am looking at are OD 16mm (http://www.bitspower.com.tw/index.php?main_page=product_info&cPath=155_165&products_id=3475), so any tube with OD 16mm should fit?
edit: removed the competitor link.
As they are reasonably cheap for the size you get.
Thanks!
