Help me choose a build!
10 Oct 2011
Would anyone disagree with these parts for a mid-range gaming build? I'm a first time builder and am not sure where to spend my money.
Cpu: i5-2500k or i7 2600k (probably i5 going by gaming performance)
MoBo: Asus P8Z68-V
PSU: Corsair tx650M (do I need higher if i want to use xfire in the future)
Case: Cooler Master Haf 922 (Need a mid-tower)
HDD:1Tb Seagate HDD
Ram:Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
Cooler:CM Hyper 212+ or Gelid Tranquilo (likely to overclock to ~4.5GHz in the future so will these coolers be enough for this?)
Gpu: Nvidia Geforce GTX 460 1gb (really not sure- I would like to spend less than £200 and then pick up a cheaper one in the future and run crossfire/SLI)
Also is it worth getting an internal wireless card or not?
