Help me choose a case please.
30 Jan 2005
Inverness
Got itchy feet regarding my case. Currently using a montech King 95 pro in white I still think it looks great but I got a black desk earlier this year and it looks a little out of place. Also more importantly with the side panel on my 5090s power connector approaches 80 degrees which makes me uncomfortable.
Here's the criteria
Black
Plenty of RGB and included fans
Room for an 5090 solid and wireview Pro
Room for at least 2 x 2.5" and 2 x 3.5" drives
Room for my seasonic 2200W PSU (I had to trim the montech)
Supports E-ATX motherboards ( I have an X670-E Meg Ace I'd quite like to use
Excellent cooling.
It sits on the floor next to my desk so it needs to be no wider than 320mm ( I have 350mm space but if it draws air in from the right side it would blocked at 350mm)
Budget not too big a concern within reason.
Can anyone suggest something that fits the bill?
Thanks
Scott
Does it have to have RGB ?
The Antec Flux PRO is a buetiful and case comes with 6 fans .
This seems to fit.
Spray job!
If I had a RTX 5090, I'd be paranoid about the power connector so I'd get a wide a case as possible so that any bends of the power connector can be as gentle as possible. That the Antec Flux Pro advertises 190mm CPU clearance - which is a good proxy for width for GPUs - then of the two @mickyflinn mentioned that's the one I would go for.
On a similar idea:
That is even wider with 205mm CPU clearance.
Or this:
but that "only" has 190mm CPU clearance.
Personally I like the wood look (Im using a Sharkoon Rebel C70M whose wood is definitely not real), but for an all black desk maybe wood is not a good fit.
EDIT: at just under 100 litres, that Phantek is huge though!
