Hi
I can't make my mind up
The bike looks like this (without the extra long number plate holder)
Which slip on would you go for from the ones listed below only.
350mm s/s oval
350mm carbon oval
320mm s/s tri-oval
320mm carbon tri-oval
350mm s/s oval
350mm carbon oval
320mm s/s tri-oval
