Help me choose please
29 Sep 2004
Hi all,
well i want to change my motherboard/cpu as a temporary upgrade until i do a major upgrade in 2007/8 i guess...
i want a motherboard which is AGP and will support a 939 A64 4000+ -OR A- 939 X2 4400+ (are there any agp boards which support the X2 939's?), just so i can use my DDR400 ram and my agp card since i dont have a major amount to spend at the moment.. if there is any "still avaliable" boards which are good for overclocking and u have experience with them then let me know please :)
Thanks,
Petros
edit: was looking at a Epox EP-9NDA3+ or a AV8 but i cant find any to buy =/
iCe-BLaZeD said:
I want a motherboard which is AGP and will support a 939 A64 4000+ -OR A- 939 X2 4400+ (are there any agp boards which support the X2 939's?), just so i can use my DDR400 ram and my agp card since i dont have a major amount to spend at the moment..
MSI K8N Neo2 Platinum is one of the best S939 AGP boards :)
heh ok well funnily enough just after i posted this i started looking at the Neo2 Plat boards.. but also cant find any to buy... seen one on .. err.. i popular auction site though
