- 4 Oct 2005
- Herefordshire
So now I can upgrade my graphics card(finally).
Il be getting one the end of next week.
Budget is £640
My budget I can not go over.
My current card is in my sig, same as my system.
I have no idea what card to go for I wasn't the fastest card out of the box, as I do not think many over clocks are 24/7 suitable(runs and hides for saying this)
so I have no idea which card is best between the makes and models, there are so many now. after the card Is setle din I do plan on playing and ocing it a bit.
IS x2 290xs within my budget ?
Does my mother board even support x2 Nvdia or amd cards.
When I finally pic the card which is the best way to connect it to my monitor.
HDMI - - DVI ---display port if the card has it.
I currently game on a 27 inch monitor at 1900x 1200 hoping to move over to a 29 inch super widescreen.
So if you recommend a 780ti wich make and model and why you think its better.
or as I said do I have enough cash for x2 amd cards, I would prefer NVidia tbh.
Thank you for the help in advance.
Budget is £640
