Hey chaps, her bimmer's in a bit of a state. (Black, e46)
I washed it today and after about 3 buckets of shampoo I'm not happy with it! It hasn't been washed since before winter:/ We also have a couple of lime trees outside. Birds like to sit in those trees and relieve themselves.
Stuff that's wrong:
Wheels, Spent ages scrubbing these but there's stull a lot of ingrained brake dust.
There are a couple of areas where the lacquer on the paintwork has been damaged. about the size of a penny. I'm guessing these are due to droppings.
There is still sticky residue on the roof from tree sap. Feels like sandpaper when dry
I'd be pretty happy if I can fix up those things myself without too much cost. Although I'm not holding up much hope for the dropping marks.
Stuff I have to use are:
Turtle wax shampoo/polish
Turtle wax liquid wax stuff
Auto glym super resin polish
Sponges and raggedy cloth thing
Cotton polishing cloth
I've also just bought some autosmart tar and glue remover as recommended by mrlol here, it better work!
I'm hoping that the tar and glue remover will sort out the sap on the roof, will it work on wheels too? If not is it worth getting a wheel cleaner? (I remember we used to have some spray for the wheels, i think it was acidic, nasty stuff to breath in but got rid of muck well)
So... How would I tackle the bird poo mark? From my internet research, I could use some 2000 grit wet and dry paper to smooth it off, then use a polishing compound and finally wax it. Would the auto glym polish and turtle wax be suitable for this? Or would I need something better.
I would finally like to polish the whole car, do I need to get a block of clay before this? I've polished before but never this dirty, worried that if there's any grit left on, polishing will just damage it further. Anywhere I can get cheap clay if its needed?
Stuff that's wrong:
