- 24 Jan 2003
- Staffordshire, UK
I've ordered a 750D with my watercooling loop of which I am going to mount a 280 rad and a 360 rad for CPU and GPU watercooling. However I've since been looking at the 780T and I love the looks, the 750D is nice but its a bit old fashioned with it's boxy square looks, considering I'm upgrading from the 550D I fancy a change.
Since I'm still waiting for my watercooling components to come in stock I'm seriously considering changing my order of the 750D to the 780T can anyone convince me or put me off the 780T? Apart from its obvious plastic construction rather than the 750D aluminium look are there any downsides to the 780T?
I've watched a few youtube vids but I want some user opinions on real builds (especially water cooling) on the space inside the 780T:
* Is it smaller or bigger than the 750D?
* What's the build quality like?
* Is air flow a problem?
* Is it a quiet case? The 750D strikes me as a noisier case as it is rather open with air holes everywhere.
* Can you mount either a 360 or 280 rad in the roof without blocking the drive bays? I'm plaining on using both of the bays for blu-ray drives.
Thanks for any info.
thanks for checking anyway!
