Hi Guys,
Okay so I recently ordered the 24" AOC 144hz but I think its going straight back as theres a better deal for the 27" version for like £20 more but my question is this once this ones gone back as I literally just ordered it so it should be fine to send back which of the two below should I go with or is there something similar in the same price range worth getting.
I see everyone rave over G-SYNC so heres the ones im considering getting as its what I originally got and just going up to 27"
https://www.overclockers.co.uk/showproduct.php?prodid=MO-027-AO
at £209.99 it'll cost me £30 to go up.
or this
https://www.overclockers.co.uk/showproduct.php?prodid=MO-022-AO
which will cost me like £140.
the money difference between the two isn't really important its more is it worth getting G-SYNC.
I have as you can see in my Sig a Nvidia 980ti thanks guys I await your responses!
or this
