I know the location of a built but not ridden XL.
you do ?
well I was in Evans for about an hour chatting to one guy there, and they didn't have much in stock in my size, but I tried a Trek Domane 5.2 I think it was, in a 58cm but was too small, I then tried another bike (cant remember the name) in a 60cm and it was a good fit
So we had a look on there system and most of the ones he recommended was out of stock until the new year
There was one Domane that I could potentially get though, but it has only a Tiagra group set, is that a bad thing?
I said to him I'm after more comfort rather than racing, and he said most if not all brands do different versions, one for racing and one for more comfort
trek for example I'm looking at a Domane as its built for comfort in mind and doesn't have the aggressive front end
We were looking at Scott, Fuji, Spesialised etc
then I popped into Halfords (waste of time) then went onto my local independent specialist shop, and they only do Bianchi and Felt, looked at a Bianchi (was £2200) in a 59cm and it was perfect fit and he said if I was to go for a Felt to go for the Z model for what I wanted in a bike.
Also he said make sure you test ride before buying any bike, to 100% make sure its the right size for me and comfortable
He also said that different manufactures have different sizing , so one bike at 60cm could be the same in another brand at 58cm for example
So what's your take on this? I not sure what to get its all confusing!
coming from a MTB I probably would be happy what ever I get though!
