Help me decipher this RJ45 socket wiring
6 Oct 2004
Birmingham
Moving some cabling around, and forgot how confusing these socket wiring diagrams are (probably dead simple really, but I'm not sure if I've got it right)
How would you wire up this socket, based on T568B (numbers added by me - I can't see any numbering against the actual connectors):
I've currently got:
1 - orange
2 - white/orange
3 - green
4 - white/green
5 - brown
6 - brown/white
7 - blue
8 - white blue
However I'm fairly sure this is wrong; the numbering on the colours is confusing me - as they don't correspond with the pin positions.
It's currently working fine at GB speeds, but only because I have the same socket wired up the same on each end. I have a new 2 port faceplate I need to wire between these 2, and it has a completely different wiring diagram, so I need to make sure I actually get them connected properly!
Thanks.
Edit:
Here is one of my current sockets:
You will want
1 - Orange/White
2 - Orange
3 - Green/white
4 - Blue
5 - Blue/White
6 - Green
7 - Brown/White
8 - Brown
The numbers in the pic are telling you which PIN to put each cable into, you can see B is the right column and the green part has a 6 in it, whilst the blue part has a 4 in it and is always 4 regardless of A or B (A and B is just a swap of the green/orange cables).
Edit - ignore me I should look more closely as the pins themselves are not numbered I would therefore have to assume the numbers on the sticker relate to the pin next to them and so your order would be correct.
Thanks - yes, it's the numbering which confuses things (how do I know which pin is #1 and which direction it goes?), hence I just went with the actual colour positions
The pins are numbered
2 8
1 7
6 4
3 5
Looking at the two top-left slots (2 and 1) as an example, if you're using T568A would be green in 2, green/white in 1. If you're using T568B then it's orange in 2, orange/white in 1.
Am I missing something?
Thanks, that makes sense then :)
The worrying thing is, 10 years ago this was part of my job :cry:
I swear they were much clearer before...
