So yesterdag I was driving my rx8 up a hill doing 60, put ny foot on the gas to ovettake a lorry. Car revved quickly like I had pressed the clutch, then the rpm lowered and car carried on.
I presume this was the clutch slipping?
I have tried putting the car in third/fifth at idle to see if it stalls, and it does.
I can reverse fine when cold and hot.
The engine has a lot of vibration at idle until clutch is presed then dissapears.
car drives perfectly fine, it's only when I give it the beans around 4k rpm it struggles for a couple seconds
Cheers!!
Cheers!!
