- 20 Jan 2009
- Worcestershire
Hi all,
For a few months now, (with the setup in my sig) I have been getting constant BSOD's on the Vista loading screen ever since overclocking. It normally takes 2-3 attempts to get into Vista.
I have settled for a decent overclock of 3.7GHz, and I know that it's stable hence these results on a Small FFT's test in Prime95.
And the NB voltage is 1.3500V.
I still don't understand why it takes 3 attempts to get into Windows with a stable overclock. My RAM is on the QVL for my mobo so that should be OK.
And the high temp you see in CoreTemp is because the CPU was just winding down from the stressing.
Any help on sorting out this problem would be great, it's really starting to annoy me!
Thanks.
Thanks.
