Help me do some bangernomics! Updated with purchase!
Long MOT, as long as it drives ok, rust is ok as long as you class the cash as disposable and see it as you're paying to rent a car for 6 months.
I had my engine rebuilt and got it done by a mate for very cheap doing it between jobs etc. In the meantime I went on FB marketplace, picked up a Fiesta for a few hundred and ended up running it for a year and got £100 or something back in scrap. Less than £10 a week.
@wesimmo that's the plan, essentially renting a car so that if I don't pass the probation period I'm not tied into anything longer. If it lasts longer than this then awesome if not no probs.
Under £1000, not tiny, petrol and that will last until the end of time?
Surely it's got to have a Volvo badge somewhere on it?
I mean I paid £1000 for my S60 T5... Theres literally nowt wrong with it, it goes like **** off a shovel, and has heated seats, dual zone auto climate, cruise, a great stereo, and yadda yadda...
Bought it as a temp car but ended up liking it so much that if I replace it, it will have to be with another 5 cylinder Volvo. :D
we had a 03 2.0L auto accord which was completely faultless for the 10+ years we owned it, even when we got rid at 170k, my £1k would be on one for most likely trouble free motoring for 6 months
That Accord looks like an excellent shout, Honda's are pretty bombproof. We had our old civic from new for 10 years and 110k+ miles and it was rock solid - the wife refused to consider replacing it with anything but a newer civic.
As long as you are willing to put up with the inevitable ridicule, Honda Jazz is very hard to beat!
However. Avoid the Autos, and for the manuals, particularly if it is an older one (Cant remember dates as such) listen out for gearbox shaft bearing noise.
It is an easy enough thing to fix, even fro a DIY'er, but for strict bangernomics, you do not want to be having to deal with avoidable problems.
Haven't bought anything yet, but sorely tempted by this:
https://www.gumtree.com/p/volvo/volvo-850glt-2.0-saloon-manual-135k-miles./1337485859
Only issues I can see (that could be monumentally against it) are that it's done less than 10k miles in 10 years and that the last oil change could perhaps be 5 years ago (4k miles by MOT)!?
Link is dead for me.
Wouldn't worry about the oil situation, just flush it through with a short change.
My MX5 hadn't had an oil change in 5 years.
So I took the sensible option and bought this:
Oil, brakes, suspension and engine look to be in good order. Getting an oil change done and an inspection by a local Volvo specialist. Got tonnes of service history and whilst not 100% perfect paint in a couple of areas no bodywork rust or damage. Clutch is also good!
Drives really nicely, so quiet and smooth and respectable power, can easily keep up with other cars on motorway etc. If it lasts 6-12 months with no big bills I'm on a winner.
I personally opted for a 2003 mk1 1.6 Ford Focus as my budget motoring car, the car set me back £550 plus I invested £220 for a garage to renew the aux belt, cambelt and water pump as well as a further £50 on parts to complete a full service myself on the drive.
At the time of purchase in November the car had done 98k, I've now taken it up to 103k and in all fairness it has been brilliant, far exceeded my expectations. Parts are also very cheap so should be easy to keep on the road providing nothing major on the car fails.
Example prices from Euro Car Parts/Car Parts 4less (with discount codes):
Disks and pads - £35
Track rod ends - £21 (for 2)
Anti roll bar links - £14 (for 2)
Price definitely high (unless sub 100k mi) and generally not a car that one buys looking for cheap motoring. That being said, if well maintained driven regularly then they are pretty reliable.
Still, not going to bash your decision as these 850s are great cars, they look fantastic in my eyes - not that I'm biased or anything!
GLT with the winter pack so not a bad spec - depending on how much original owner decided to cost cut anyway. I see the steelies which probably means they cost cut a lot! GLTs should come with half-vinyl and half-cloth seats at a minimum - pretty comfy but also easy enough to swap for full leather options, full interior sets normally sell for £100 of so. If you did want to upgrade the wheels you can find OE alloys ranging from £60 a set to £150 depending on condition. The 15" Cetus alloys would have been the normal spec on GLTs and the 15" size makes finding tyres slightly easier than with the 16" alloys that are available. Avoid anything 17" (have to run bizarre tyre sizes and still rub on full lock) or anything more than 7J (simply don't fit up front on the 850s).
If your heated seats don't work it will be the wires to the thermostat (repairable) or a break in the heating element (eBay replacement).
If A/C doesn't work its probably because the compressor clutch gap is too large (ziptie fix), or the evaporator is holed.
If you don't have a pollen filter find one. Can buy aftermarket housing for £15 or so or genuine used for £10-15; the advantage of the pollen filter (aside from the obvious) is it stops debris from getting into the back of the blower motor and evaporator. Remove the two passenger side T25 screws on the scuttle panel to check.
Definitely replace brake fluid if it hasn't been done in the last two years or the car has been sitting. I had to rebuild three calipers because of this scenario leading to brake fluid absorbing lots of water and then rusting calipers from the inside out.
Definitely check the PCV or make sure you have receipts for it being done within the last 50k. If not you'll be doing it very soon and it's a real pain - not that cheap either. Two ways to check, either by looking for smoke coming out of the dipstick tube whilst idling at temp, or by putting a rubber glove over the oil filler hole. If the glove inflates whilst the engine is running then you have a PCV issue and need to service it. If it gets sucked in then you have a good system. Obviously you need to secure the glove so it doesn't get eaten!
10W40 is the correct grade oil, don't deviate! Can go fully synth or semi-. Doesn't really matter as long as it meets the right specs and is the correct grade. Some claim that the high-mileage specific fully synth oils have helped with oil consumption and reducing oil leaks. If you get semi-synthetic then Volvos official service interval for the oil is 10k - but most oil companies would recommend changing every 5k (and so would I), fully-synth is perfectly fine at 10k intervals.
Oh yeah, sunroof drains. Keep them clear regularly, they have a horrid habit of clogging frequently - which results in water pouring into your passenger footwell and behind the dash.
Awesome @Cookeh will go through that at the weekend. I did the rubber glove test albeit with a plastic bag and it didn't blow outwards so seems good will redo when I get back home to check it out. Heated seats work but there was a battery drain on the drivers so it's disconnected, need to investigate that but new battery and distro cap that tests fine on my tester.
Got the half leather seats in it and a/c works fine. Not sure why they didn't get alloys but I'll pick up a set if I decide to keep the car in the future.
So update on this:
It's running fine now. Found that the rear shocks were gone, fronts struts and coils were rusty as anything but working, I managed to get donor parts and a set of calipers that were all in good order so got the suspension fitted. Calipers are fine and braking is fine (pads and discs with lots of thickness and no problems) so didn't fit the donor ones, will keep them for the future.
Unfortunately the timing belt hadn't been replaced and I don't trust myself to do it right so I had to fork out for that. Got a service done and car put through MOT early. It's now running fine, pcv valve cleaned but wasn't that dirty etc.
Only other issues left to sort are alternator which is whining so that will be done asap once I find one, aux belt will be replaced then though the one on it is grand. And the clutch occasionally makes a noise into first but doesn't slip etc so fingers crossed will last a long time.
Tyres are out of date but visibly ok with lots of tread, I'll replace these within a couple of months if they don't get punctures in the mean time.
Overall very pleased with it and it's in a good condition. Will see how long it lasts/I keep it but for a daily commuter it's fine. I love the looks and feel of driving it, I know it's nothing properly special but it's a laugh. And the slow acceleration adds excitement to who you can pull out in front of round lorries haha!
Excellent stuff, glad you're enjoying it. What kind of noise on the clutch front? If its a sort of squeak it's possible that your slave cylinder is on its way out. If you have an external slave (you should, given the year and engine) then its a very easy job. If its an internal slave then you're in for a bit of bother - it's a gearbox out job, at which point you might as well replace clutch, pressure plate, and rear main seal at the same time. If its more of a clunky noise it is possible that your pressure plate is worn (a very heavy clutch is a giveaway too, though these do have heavy clutches anyway).
Yeah it's a squeak and only in first either going into gear from a stop or pulling off, and not every time.
I'll check the slave cylinder and see what is entailed in replacement. But the clutch isn't overly heavy anyway, and hasn't changed in the few hundred miles I've done so far.
Thanks for your help thus far Cookeh :)
