Help me do two things at once!! (poverty spec)
11 Mar 2005
Scotland
So my ageing (2007) Macbook Pro properly died the other day and I'm reverting to using a desktop. The one I have is bodged out of gifted and salvaged parts which was fine when it was just and emergency backup machine but now its being pressed into service I'm finding it a little lacking. My uses are primarily Photoshop, Lightroom, AutoCAD and of course general web browsing, word processing, etc. I'm not fussed about gaming.
My plan is to buy a new system as soon as my funds allow but for the moment and for as little money as possible (second-hand is fine) I would like to improve the performance of this heap. I'm not looking for the impossible but I would like to be able to work in Lightroom and and use a web browser at the same time!
The current specs
Processor - Athlon X2 7850 2.8Ghz (stock cooler)
Mobo - ECS 6100PM-M2
RAM - Hynix 1GB DDR2
Graphics - Onboard!!!
PSU - 400W Akasa
HDD - 1x200GB Maxtor (IDE), 1x1TB Samsung
I'm confident that a bit more RAM should be my first port of call, say 2x2GB. It must be 2xsomething as the shoddy motherboard only has 2 slots.
Other than this I'm a bit lost.
Obviously any graphics card at all would be an improvement but I don't know anything about cards that would be suitable i.e. not so 'new' as to be bottlenecked by the rest of the system.
Would the PSU cope with a graphics card of recent vintage, it dates from my X64 Athlon with X800XL graphics days.
I also have a 500GB HDD from the MacBook which although 2.5" is a 7200rpm drive, how would this be as a system drive?
Any help much appreciated as always OcUK :)
http://www.ecsusa.com/ECSWebSite/Pr...oryID=1&DetailName=Feature&MenuID=20&LanID=11
Your mobo should support a quad core if you could afford one/find one second hand?
And that HDD sounds fine if you can mount it in the case okay, though isn't that 1TB samsung drive pretty fast/good enough?
Do the programs you use actually utilise graphics power though? If not, I wouldn't bother.
Definitely more RAM, but unfortunately DDR2 is quite expensive, see what you can find.
Are you likely to upgrade the whole thing, what sort of budget are we talking here? I'm just think you don't want to invest too much in an old rig if it's gunna be replaced.
Thanks for the reply.
Any ideas what sort of price I would be looking at for a second-hand quad?
I was thinking I'd use the 500GB drive to replace the 200GB IDE which is the current system drive, hopefully gaining a bit of speed? Mount wise I can blag a couple of mounts from my mate so that's not an issue. The other problem is if I just used the 1TB I'd be at around 800GB used which doesn't leave a huge amount spare.
I was under the impression that Photoshop etc are capable using the card for "hardware acceleration" and if nothing else it stops the on board graphics from stealing my RAM?
DDR2 does seem steep but it's always the same once the newer stuff becomes mainstream I reckon I can do 4GB for £25ish on the MM.
I'm planning to replace the whole lot ASAP hence the minimum possible spend. I'd leave it alone completely but it really is barely usable! I'm thinking a 2500K level of spec for the replacement with some insane amount of RAM and perhaps a Quadro type graphics card. (which I didn't know existed until tonight!)
sell macbook pro, sell your computer -> buy cheap i3 rig :)
Think the old rig is worth much? The Macbook Pro has a terminal logicboard/graphics card fault and is pretty battered outside I'm not sure its worth it either, maybe as parts?
£10-65'ish if you look around the MM, really depends what you can find that works in the board.
It would be much better to focus on the new computer, anything you buy for this apart from say a cheap gfx card wont able to be used in the new computer.
The money spent on new ram and a cheap gfx card, would go a long way to getting a low budget new build.
@stulid, thanks, if I can get something at the lower end of that then it's bearable.
@beejjacobs Thanks for the links, whilst they don't specifically mention the software I'm using other parts of the site do which is promising more reading required I think. Mac being as bricked as it is I'm thinking parts is a better selling solution.
@****199 I'd love to not waste my money too but looking at 2+ months using this heap makes me want to cry! I think I'll try the RAM initially. There's not much of a new system £25 would buy surely.
Graphics wise does anyone know what I'd have to spend to beat the on-board? I'm guessing peanuts but graphics are my weakest area.
A ATI5450 will beat the onboard solution, so if you get something faster again then thats extra gravy.
Obv that's the most basic thing OcUK sell, is it "good" enough to suffer from the rest of the system being crap? Could I go cheaper/lower spec via the MM and not loose performance?
Obv that the most basic thing OcUK sell is it "good" enough to suffer from the rest of the system being crap? Could I go cheaper/lower spec via the MM and not loose performance?
Depends what you can find, a ATI4850 or a Nvidia 8800Gt/9800gt etc, so many cheap cards out there that will dump on the onboard solution.
Your 400W PSU will be alright with these cards.
That was my concern with any of the older more power hungry cards, thanks for the help. Time to get trawling the MM then!
Edit, forgot to mention this earlier but my monitor is running at 1920x1200 should this be a concern?
Those sort of old cards only need a single 6pin extra power connector, nothing to hungry.
How many AMPS does you PSU chuck on the 12V? or do you have a model number?
That's it, it's always been rock steady in the variety of machines it's seen use in :) I wasn't too worried about the CUDA until I replaced the system as I didn't realise the gaming type cards could support it, interesting.
Thanks for all your help this evening chief!
