- 18 Oct 2002
- UK
So typical situation, 10-13 year old fridge is working fine, unplug it to do some hoovering, plug it back in, thing doesn't work, has power, leds light up, but no compressor action. An 'error' of sorts is lit up on the display, but not an error code you car read, just fully lit up screen = error.
Couple of linked pics (huge for detail)
http://i.imgur.com/t719C.jpg
http://i.imgur.com/GvjpE.jpg
When plugging it in I can hear a click from the area of the board that has the blue square relays in (top left) but nothing else, the transformer is outputting DC (measured with DMM and the display lights up)
Can't see any broken fuses (there are only two)
Nothing looks burned
It's a twin fridge (side by side) so has 2* temp sensors and 'heaters' (marked on the PCB) so a bit more wiring than normal. I know a tiny bit about compressors and run/start capacitors but don't know how to check them!
Anything obvious to do?
Oh, should say of course it's a Samsung skr1370g but I don't think that'll help much, it's a Korean specific old model.
The PCB has 240 Volts running through it ok, but it isn't outputting anything to the compressor, guessing one of the relays/chips has thrown a wobbly and won't let it run
Unless I can track down a PCB from 1999 this whole fridge is now junk
