Help me fix my PC!
18 Oct 2002
London
My 2nd PC is dead!
It powers up (the fans spin up) but there is no POST, no beeps, no drive activity.
I have tried swapping out the RAM, CPU, graphics card and motherboard, but no joy.
Is it likely to be a dodgy PSU? I don't really fancy spending even more money on extra bits which won't fix it!
Thanks!
Not a spare, but I have one in my main PC which I don't really want to rip out if I can help it.
Is a dodgy PSU likely to be able to power up all the fans (including the ones powered by the motherboard) but not start the PC?
I suggest giving it a go if you do have a PSU available, It may be a hassle but it will be worth it when you either find the PSU is at fault or eliminate it as a problem.
I'm no expert, but i'm guessing a dodgy PSU could turn on the fans and not the system, the fans will run on any old voltage, unlike the mobo.
The last thing I did before it stopped working was attempt to fit a PCI-X card, only to discover PCI-X wasn't the same as PCI, so effectively, I didn't really do anything.
Well yeah it might be the PSU like cmndr_andi said; if you swapped out the motherboard. Try only plugging in the graphics card with the PSU cables and try to boot.
If you have a multimeter to hand you could test your 'suspect' PSU in situ - although ripping out your other PSU is a definitive test.
Huddy's site has a step by step guide on how to 'Use a multimeter to check your PSU' and one to 'How to check if your PSU is faulty'
