Things I have tried today, took the air filter out again and tried to get it started, chugged a few times and a loud backfire here and there. Took plug out it was a little bit wet, but i dipped the tip in some fresh petrol and put i tiny bit in the cap and threw that down engine where the spark screws in. Tried to start a few times wouldnt kick over, no real signs again apart from a backfire.
Under the carb there is like a copper or bronze bowl thing that has two screws, undone one of the screws and about 2 cap's of fuel came out, that was emptied, done screw up, went to start, took a few goes it backfired once, then started for about 10 seconds, it was dying so I opened the choke a little but I couldn't save it. Wouldn't kick over then again.
Do you think its worth buying another plug?
Did find a good guide though which re-iterate what's been said in this thread, when I have some time next weekend possibly I am going to go at it from the start.
http://www.toolsandpowertools.co.uk/blog/2012/03/27/faq-difficulty-starting-generator-after-storage/
