- 27 Feb 2006
- Normanton
Ive got a 500gb Lacie drive, last week i threw the power supply out to what i thought was an old cable modem. I thought i lost the lacie adapter so went on a mad hunt for about 6 hours, I tried a laptop adapter because it had the same connection but didnt work (green light powered on though)
I remembered binning the modem adapter to dug it out and tried it on the lacie drive but it didnt power up and no green light.
Turns out i binned the lacie power adapter, although im sure it was the cable modem one.
So, I have either knackered my drive by plugging in the laptop adapter (higher output voltage and amps) or the plug i binned is slightly damaged by sitting in the bin for 3 days (although it still powers the cable modem)
Has anyone got a Lacie drive with adapter in the leeds area that i could test on mine before either buying another adapter for £22 that may not work or opening the drive to try it on my pc. -Doing the latter wont solve much if it does work because i need it to power from mains and something may be damaged on the mains input to the drive
Cheers
Cheers
