- 1 Jun 2012
- Hereford
Stable at 3600mhz. Fclk is at 1800mhz at the moment. Tried 3466mhz on fast and stable for a 2 hour warzone gaming session. Took it up to 3600 on safe. Carried out 4 passes on memtest and so far OK.Ignore that.
The two variables are what your maximum stable FCLK is on your CPU and then can you run your ram at that speed.
2 x FCLK is what you run your ram at. But that doesn't mean it''ll be stable. You need to test it.
