HELP ME OVERCLOCK PLZ
Permabanned
9 Oct 2006
Norwich
Hi
I have got a GA-8N-SLI(Rev 1.1) and a Intel PD 920 2.80ghz at the moment it is over clocked to 2.94ghz I increased the FSB to 840 and increased voltage from 1.3v to 1.425v I also increased dim voltage from 1.8v to 2.0v and increased speed of the dim from 667mhz to 700mhz I wan t to try and get the system to be able to get an over clock of 3150mhz what is 900 FSB but I don t now what else I need to do to get that speed.
LINK to mobo http://www.gigabyte.com.tw/Support/Motherboard/BIOS_Model.aspx?ProductID=2173
LINK to memory
Corsair 1GB DDR2 XMS2-5400C4 TwinX (2x512MB)
http://www.overclockers.co.uk/acatalog/Corsair_XMS2_Memory.html
First of all I suggest you lower your CPU Voltage and put the memory voltage back to how it was, that is a way too big jump. When overclocking you need to take things slowly, your motherboard should allow you to increase the Vcore at .125v or simular increcements.
You have decent overclocking ram and therefore it should not need a voltage increase at this stage. Gradually increase the FSB and test stability with something like Prime95. If its stable, continue, if not try increasing CPU temperature only slightly, and watch temperatures.
Chris.
Prime95....as per Wikipedia:
Prime95 is the name of the Windows-based software written by George Woltman that is used by GIMPS, a distributed computing project dedicated to finding new Mersenne prime numbers. As of September 2006, ten new Mersenne prime numbers have been found by the network of participants, and, on average, a new Mersenne prime is discovered every year. The Linux-based version is called MPrime.
[edit] Use for stress testing
Over the years, Prime95 has become extremely popular among PC enthusiasts and overclockers as a stability testing utility. It includes a "Torture Test" mode designed specifically for testing PC subsystems for errors in order to help ensure the correct operation of Prime95 on that system, which effectively stress-tests a PC.
Although it is hard to judge precisely how many people use Prime95 as a stability test, the adoption is almost universal. Most, if not all of the overclockers and people who want to make sure their computer is completely reliable are using or have used Prime95 in the past. [citation needed]
The stress-test in Prime can be configured to better test various components of the computer by changing the fast fourier transform (FFT) size. Three pre-set configurations are available: Small FFTs, In-Place FFTs, and Blend. Small and In-Place modes primarily test the FPU and the caches of the CPU, whereas the Blend mode tests everything, including the memory.
By selecting Custom, the user can gain further control of the configuration. For example, by selecting 8-8KB as the FFT size, the program stresses primarily the CPU. By selecting 2048-4096KB and unchecking the "Run FFTs in-place" checkbox, providing the maximum amount of RAM free in the system, the program tests the memory and the chipset. If the amount of memory to use option is set too high then system will start using the paging file and the test will not stress the memory.
On an absolutely stable system, Prime95 would run indefinitely. If an error occurs (the tray icon will become yellow from the default red, indicating that the test has halted), there is a chance that the system is unstable. There is an ongoing debate about terms "stable" and "Prime-stable", as Prime95 often fails before the system becomes unstable or crashes in any other application. This is because Prime 95 is designed to subject the CPU to an incredibly intense workload, and to halt when it encounters even one minor error, whereas most normal applications do not stress the CPU anywhere near as much, and will continue to operate unless they encounter a fatal error.
In the overclocking community a rule of thumb is often used to determine how long to run Prime95: test the CPU (8KB FFT) for 10 hours and the memory (4096KB FFT) for 10 hours, and if the system passes, there is a high chance that it is stable.[citation needed] Moreover, true "hard-core" system overclockers and enthusiasts alike favor Prime95 over other benchmarking suites because Prime95 pushes the CPU's floating point units extremely hard, turning the CPU extremely hot. Inadequate cooling is the most common cause of Prime95 failing.[citation needed] In addition, Prime95 stresses a computer machine far more than the majority of software based torture-suites. The nature of this is because the operating system usually shuts down the floating-point unit when unused by other programs, whereas Prime95 is well-optimized to continuously and effectively thread the FPU, resulting the FPU to be deeply pipelined thereby generating significantly more heat because of elevated power consumption under the massive workload conditions. In CPUs not properly cooled, errors will occur. Prime95 also constantly accesses main memory up to 60MB per second. This constant activity will detect memory problems that other programs do not.
Lastly, power supply units of any machine running Prime95 are subject to the consistent ramifications of such harsh conditions. Power must be maintained clean, while providing adequate yet persistent voltage regulation mainly to the CPU RAM and chipsets (Mainboard Chipsets such as the Northbridge where the memory controller may or may not reside, see Athlon64 for on-die memory controllers) to provide peak (nearly redlined) performance while maintaining absolute stability. Stability being the obvious non-elusive most important factor, it is primarily the reason why Cray Research used programs similar to prime95 diagnostics package for over a decade.[1]
So there ya go =D not sure about linking downloads to this board....so, if you need it, pm me or some1 and Im sure we can sort out a link for ya =D
