Help me pick a fan controller to my Stacker STC-T01
17 Dec 2005
I'm on the lookout for a new fan controller to my Stacker STC-T01. I'm a fan of LCD-screens, IF they are of good quality and can provide somewhat useful info... Anyhow, I've been looking at a few:
Silverstone Eudemon SST-FP52: Nice aesthetics, but a no go because of no manual control... Useless. http://www.tomshardware.com/2004/06/15/fighting_fan_noise_pollution/page7.html
Akasa All-in-one: Fairly nice aesthetics, but only 2 fan channels: http://www.akasa-europe.com/akasa_english/spec_page/control_panels/spec_ak_all_01bk.htm
Do you guys have any suggestions? Don't know what to get really :confused: . And is there any fan controllers where I can save different "modes", let's say one "gaming mode", one "desktop mode" etc.?
I already have a sunbeam rheobus, which does the job good. But I still want something else than just knobs you can twist... Any ideas?
What's happened to all the decent fan controllers? I can't seem to find more than a couple of decent fan controllers anywhere.
There used to be loads of choice, now theres none.
I use a coolermaster aerogate 2 and i would recommend it if you can get hold of one, it looks good and does the job. My only issue with it is it doesn't remember previous fan speeds very accurately, so when you switch the pc back on the fans will be running at a slightly higher speed. Although they may have fixed this, its had a few revisions.
Don't think they're selling the aerogate 2 anymore... Didn't quite like it either(tell me I'm picky :D )
I've been looking at the aerocool coolwatch as well, but I'm not sure if I like it, and most of all it's really expensive... Jesus, how hard can it be to pick a fan controller :p
sablabra said:
Fair enough, care to elaborate a bit? ;)
Well its got four knobs which vary the speed of 4 fans. Just like every other fan controller. :p
Doesn't look very nice though imo.
Nail. Head. Hammer. :D
Of course the looks won't appeal to everyone, but meh :p
The temperature probes are quite handy and the lcd panel is actually usefull, shame the controls to adjust the alarms for high temperature etc are a pain to set up.
btw, just wondering about a thing. I want to connect 3x yate loon D12SL-12 fans on one channel. That should be about 0.9A, or 10w(?). Will the scythe kama be able to cope with that? :)
i tried 2 fans on the 1 channel but the lcd display could not show the correct fan speed (kept displaying different speeds)
it works perfect with 1 on though :D
