- 9 Jun 2008
Everything is at stock speeds, as I have not attempted to overclock my computer till I get my new graphics card.
Ok basically I know its overheating because one; when I am playing games about 10 minutes in I get artifacts, a few minutes later the whole screen is a rave show...this is in all the games I've tested...number two...when I have all my fans turned up to max...it doesn't do it.
My specs are as follows;
Hiper Osiris Case
3 X Noctua Vortex control fans
Zalman fan controller
AMD Phenom II 550 Dual Core
Thermalright extreme HS with 2 X Enermax magma fans
MSI 790FX-GD70
Corsair Dominator 2X2GB 1600Mhz/9-9-9-24 running stock
Corsair 750W PSU
BFG OC2 8800GTX @ stock
Creative fatality pro
1TB caviar black HDD
So its annoying me, my initial impression was the graphics card...even though it never did it on my old rig (upgraded everything but that), now my old case had way worse cooling (didn't have an intake or outtake fan)...but I can't rule it out so I took the cooler off it today, cleaned all the dust and even give the GPU a fresh layer of arctic silver 5 (which btw reduced its core temps by 10oC)
I am still under the impression (since there's no hint of data corruption, random crashes or BSOD's) out of a game that it still could be the graphics card however the ram chips on there.
Could it be the normal ram? It still got artifacts and then disco'd did it when I turned the ram to 1333Mhz with slightly lower volts (the JEDEC settings or whatever its called)...
I've run temp programs, my CPU runs 42 load when all the fans are on low, my motherboard around 35, the graphics card now runs 82 highest on load (previously 93 after comparing it since I cleaned and added new thermal paste).
It's only doing this now on a hot day see, and its never done it before...so I am rather dissapointed since its all new hardware and I spent quite a lot on the cooling and spent some time choosing a case with good circulation.
How can I diagnose the culprit? Thank you for your help!
Hiper Osiris Case
MSI 790FX-GD70
Corsair 750W PSU
