Help me sort out my internet
30 Jul 2008
Surrey
Hi,
I have a strange issue with my wifi connection, its works perfectly all over the house except in my bedroom. The router and modem are only a few metres down the hall so it doesn't make sense. Apparently there has always been a problem getting wifi in this room. I haven't found anything obvious causing interference and the signal works perfectly everywhere else.
My macbook, android phone and windows desktop all have the problem so its not a receiver problem. I have tried multiple wireless extenders, different modems and routers with no luck. What options do I have left? There is a phone line connection in the room so is there anything I can do with that?
Thanks
There is anything special about your room that is different from other rooms in the house? What device do you have apart from the ones mentioned ( electronic devices) in your room?
Could start with running Wireless Analyzer app on your android phone, and look at the signal pages, step in and out of your room and compare whats going on - could highlight a significant drop in dB or show interfering channels etc
might be worth having at look at the powerline options.
https://www.overclockers.co.uk/productlist.php?groupid=46&catid=1604
as a check, how close can you get to/into the room before the signal drops ?
Forgot they existed.
The signal starts dropping just before the doorway.
I think the room was an extension with one wall shared with the garage. Other devices are TV, ps3, speakers and wireless headphones.
Interesting results, all wifi signals in my room 'pulse' randomly gaining and losing strength significantly and there are quite a few complete dead spots. All goes normal when I go about a metre into the hallway.
Cheers for the help
Cheers for the help
Gremlins living in the walls, for sure.
Anything in there that could be causing interference then?
I am finding at the new flat I am in, for the usual 2.4ghz wireless setting my internet is awful (guessing all the other wifi is interfering with it) but when I swap to 5ghz runs fine.
Cheers for the help
Awww so something killing the singal what frequency is you wireless running 2,4 or 5Ghz
Power line adapters with a wireless repeater in your room would be the best bet.
Rich
Chicken wire in the walls? A shorting/malfunctioning power supply somewhere (e.g. fluorescent tubes)?
