Help me sort out my problems, please
22 Mar 2009
Cornwall
ok, so i have mentioned in several other peoples threads, and possibly some of my own about my issue since getting my 2500k chip.
basically the 2 games i play the most are F1 2010 and Fifa 11. both have become very stuttery or have ghosting.
i have pretty much solved the F1 2010 issues, but turning off MSAA. but the problem is still there, just for such small amounts of time you can live with it.
Fifa 11 though, well this is completly different. i have tried everything from turning all the settings to low/off, disabling CF, going back to older drivers and the problems still persist, although they do change. i did take some vids in MSI AB, but they are like 1GB each so a bit big for uploading :(
basically, turn everything off, and it looks poor and there apears to be only what i can describe as ghosting. like sometimes it feels like you are playing in slow motion but at full speed. turn everything up, gpu usage only goes to about 40-50% so its not pushing the cards, and its really stuttery, like you run, pause, run.
any ideas guys?
Check for any updated patches.
Look for a forum of gamers who play that specific game and consult them.
Failing that i would uninstall, then reinstall again.
there have been a lot of issues with Fifa 11 from what i have found on the EA forums, but i had it working fine with my Phenom X2. i have changed HDDs, reinstalled windows/games, tried new/old drivers. at my whits end, am i better calling it a day and waiting for Fifa 12 and F1 2011 and purchase some other games to tide me over?
EDIT : also, why cant i get it to show VRAM usage in MSI AB?
