Help me stream WoW
3 Apr 2010
I'm starting to stream World of Warcraft for a bit of fun, I know i'm not gonna get rich from it, however i'm having issues with very poor FPS.
Specs:
  • i7 930 @ 2.4GHz
  • 6GB DDR3 1600MHz Ram
  • ATI 5970
  • 2MB Upload
  • Using xsplit to stream
I normally play at 2560x1440, but I only get ~8 FPS while streaming at 720p, running the game maximised in windowed mode.
I turned in-game resolution down to 1920x1080 but this means I either have to play with the game in a window in the middle of my main monitor, or have the game on my 2nd monitor, which is not ideal.
I can make the game playable at ~30 - 40fps, but I have to change the xsplit resolution to 854x480, and play with the game either windowed or on my 2nd monitor.
If I want to be able to have the game on my main monitor (in-game resolution: 2560x1440) and stream at 720p what do I need to upgrade?
WoW + Xsplit is going to put a HUGE stress on the CPU.
An i5 may cope but an i7 would probably be more up to the task. Either would require a new motherboard too.
A GPU upgrade probably wouldn't hurt, especially with you wanting to play at 1440P.
What power supply do you currently have?
Would reusing the current case/hdd/dvdrw/psu be better for you than building a whole new PC?
