Help me upgrade - £800
25 Nov 2020
Hey,
I've around £800 to play with and looking to upgrade my PC for Cyberpunk at 1440
This is what I currently have;
Kolink Citadel Micro-ATX Case - Black 1
AMD Ryzen 5 3600 Six Core/Twelve Thread - Tray 1
Asus GeForce RTX 2060 Super Dual Evo 8192MB GDDR6 Graphics Card
ASUS PRIME B450M-A (Socket AM4) DDR4 MATX Motherboard 1
Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit 1- Grey
Kolink Classic Power 700W 80 Plus Bronze Power Supply 1
Wanting to make sure what I upgrade to is compatible with the case and motherboard, any help would be great.
Everything will work and and fit but I would up the ram to 3200mhz, the psu is low quality if you have any room in your budget I would upgrade that.
I would upgrade that poor psu to a decent quality one.
My basket at Overclockers UK:
Total: £523.51 (includes shipping: £12.60)​
You could upgrade the ram to 3600 but I dont know if it would be worth the extra cost. Overclock it to 3200/3600mhz if you can would be my advice.
All you have after that is a 5600x ryzen or a 3060/3070 or 6700/6800/xt when they are available.
Thanks for the advice!
I think I'll be getting Vengeance;
3600MHZ 32GB (2x16GB) - £129.98
750W RMx Power Supply - £114.95
Ryzen 5600x - £280 (once its back in stock)
then wait for the 30 series to come back in stock for next upgrade
Should really overclock your RAM to see what you can get from it first IMO. Don't think you really need the extra capacity.
^^ This. Dont forget cyberpunk was written to play on a ps4. Unless your planning to play microsoft flight sim 2020 there is little reason to buy 32 gig at the moment.
